1 - 4 of 4 Posts
I had C16 (front speed sensor) cause the sensor broke off, this triggered the Check engine and ABS lights to light all the time.
i just replaced the sensor, and the FI still blinks as before (i didn't ride the bike) do i need to reset the fault or it will go away once i'll ride and the ECU will see a signal from the sensor?
I haven't had that specific fault code, but my experience has been that these check engine faults don't clear themselves after your problem is fixed. I have been able to clear out mine by using the following steps.
  • Ride for 10-20 miles
  • Pull over and put the bike into dealer mode (google how if needed)
  • Code will now show as changed to C00
  • Turn the bike off, on and off while in dealer mode
Done!
Done!
i'll try that
1 - 4 of 4 Posts
