OK all, I am getting a C16 code...Speed sensor circuit front wheel malfunction....I know my speedometer has stopped working. Can anyone tell me where to start searching? speedo cable? I did replace the front tire a while back so I'm not sure if i did something wrong. I'm on a 2014 DL1000.
Thanks all
Could be a very simple fix, esp since you mentioned fr wheel/tire remove/replace...
See pic: located just below fr wheel's compression adj screw
make sure it's clean and securely fastened.
Notice the cable retainer just above and to the L of the comp setting
And just to cover all the bases, make sure it's lining up with the speed sensor rotor mounted on the wheel
I hate to admit it, but I once put the front wheel on backwards, so the sensor ring was on the wrong side. Who knew you could do that? Anyway, it became very apparent with no speedo and TC & ABS lights, etc.
In case you are interested, the computer takes input from both the front and rear ABS sensors and generates a pulsing signal that goes to the speedometer and odometer. So you don't have to worry about a separate speedo cable. Once the front sensor is back up and running, the speedo will come back too.
Ok all, thank you. I think I've figured it out now. They mounted tire backwards so I mounted the rim reversed....the sensor wheel is on the left side. Ugh
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
A forum community dedicated to all Suzuki Strom owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, purchasing, reviews, accessories, maintenance, and more!
