Has anyone gone to better brakes? Would like to find cross references of other calipers that will fit... 2014 DL 1000abs..
Thanks...
Thanks...
Please explain more about the EBC pads not fitting well because that has been my go-to for years on many bikes. Have you published results yet? Anxious to see what you have found!Writing a story of how EBC HH pads don't fit our rotors well. Have tested 5 brake pads so far this year. DP sintered so far the best. No other changes necessary. Our callipers are monoblokcs so they are fine. If you're really doing for more brakes. Braketech makes a 330-mm conversions for rotors that fit the 08-12 Hayabusa. Those are identical in spec — five hole mounting with a 121-mm centre —to what 14 to 20 DL1000s use. kit includes little spacer dowels to push the clappers 10-mm back to accommodate the 20-mm larger rotors. More leverage is more power. Swapping callipers on the other hand doesn't do much.
RL that's for early 1000's which had two-piston, split caliber front brakes. The later versions are mono block four piston and are brembo worthyA lot of people have swapped sportbike "callipers" on to 'stroms. it gives a lot more braking power. I would not trust someone who does not know this.
Google "motorcycle brake drag after new pads"and if you spend enough time looking through hundreds of threads — I'm paid to do it soI am a bit obsessive — you'll find something interesting. There are lots of discussions relating to the subject and the reasons that cause it. But what found interesting is that any time a specific brand of pad was mentioned as the main cause of the drag —it wasn't often —it was always an EBC HH. Again the pads were not often mentioned as an issue but when they were I couldn't find single instance of a brand other than the EBC Has pointed to as the culprit or even mentioned in passing.Please explain more about the EBC pads not fitting well because that has been my go-to for years on many bikes. Have you published results yet? Anxious to see what you have found!
Do you have a blog or website I can sign up for/support? Thanks!
Sent from my Moto Z (2) using Tapatalk
I don't know how they don't fit our bike well. On my 2015 Dl1000 I went through 5 sets of the HH front pads with the only issue being a tendency to squeal when applied at very low speeds when wet.Writing a story of how EBC HH pads don't fit our rotors well. Have tested 5 brake pads so far this year. DP sintered so far the best.
I don't know how they don't fit our bike well. On my 2015 Dl1000 I went through 5 sets of the HH front wheel pads with the only issue being a tendency to squeal when applied at very low speeds when wet. Very happy with them and have never had any issue with the brakes dragging apart from one time when a caliper was sticking a bit.Writing a story of how EBC HH pads don't fit our rotors well. Have tested 5 brake pads so far this year. DP sintered so far the best.
Perhaps it's the biggest selling brake pad? I know in 600,000 km of Strom riding I never thought about another brand.There was even a link here Front brake drag
Like all the others, it did not necessarily blame the pads but again every time a pad is even mentioned —on Haybusa, Triumph and other Suzuki forums — it was the EBC Has. I'm not exaggerating. Never heard another pad mentioned.
