08 DL1000 13,500 miles. Rear pads looked worn down, put on a new set. Front pads looked a little thin so I got new sets for up front, Parts Unlimited HH, $80 for both sides, not cheap. The new set dosent look any thicker than the old set I want to replace. Is it that the ones on there now havnt worn that much? I use the front brakes hard, so they havnt been getting a free ride. The little metal keeper tang is about 1/8th away from the rotor, the piston is visible but not bad, theres still a lot groove depth in the pads. I just expected a lot more pad on the new set. Should I replace them anyways seeing as its been 13,500 miles?
I also got them iridium plugs, they have the one bent tang for the arc to jump to center. The stock plugs got the fancy set up where it looks like a lot better path for the spark to fly to center, what up with that?
