1 - 18 of 18 Posts
Has anyone installed one of these on a 2019 dl1000 with factory led brake light. If so do you remember the wire Colors?
Can I assume that your unit came with a wiring diagram and that it is the bike wiring that has you confused?
The rear light assembly has three wires. Brown, white/black stripe, and black/white stripe.
The white/black stripe comes from either/both brake light switches.
The black/white stripe is earth return.
I put one of those flashers on mine last week, spliced it into the brake light wires and ran it to a couple really bright led lights under the red reflector in my Givi top box. My brake light works as normal, my top box light does the flashing.
I have had a different brand installed for a couple of years....can't remember the brand but it was way more expensive back then(around $40). Works great and keeps me from hacking up anymore wiring.
Edit....I think it was the Kisan Tailblazer. I found a 2 pack on ebay and split it with another member here.
1157 bulbs won't work in a newer 'strom, as they have LED tail / brake lights. If you want it to flash, you have to install an LED flasher, which is different from a "normal" flasher.
So the new bikes don't use any type of bulb/socket for the brake light?
Hmmmm, proprietary lighting....not sure if I like that, but I reckon it's the future.
70bones,
Did you have to remove most of the arse end plastics to get it done?
I bought a plug and play flasher unit with connectors and my manual shows I have to remove a lot of stuff to get to the rear light connector.
Yes, those 4 nuts under the rear cowl are hard to get off and harder to get back on! I started to take them off then changed my mind and spliced into the brake light wires near the connector under the rear of the seat.
70bones,
What kind of connectors? Posi-Taps/Loc's are awesome...quick and easy:
Those posi-taps would work great. I used solder and heat shrink tube, as that is all I had, and it was a pain as things are so tight there.
It is a "used" plug and play from a 2017 650 that I got off Ebay. Someone assembled it using Suzuki connectors. Nice bit of kit but I discovered it requires taking apart the back of the bike:(
1 - 18 of 18 Posts
