Hey stromies,
I added some trunk lights with an (406) 777-2397eastern beaver
Adaptor. After about 4 months my brake light now continually
Stays on. I have removed the trunk light adaptor but the light is
Still brake only. Is there a relay that has gone bad?
Anybody experience this or have a solution??
The typical problem is the rear brake light switch the pedal activates via a spring pull. See if pushing the top of the spring connector upward turns off the light. If it does, change the switch adjustment.
Discussion Starter · #4 ·
Wow, it was that easy !! Thank you, i wish i would have posted last fall... how do i change the spring tension?
You don't change the spring tension. You rotate the big plastic nut that positions the switch. To lower said switch turn the nut higher.
