Today I installed my GenMar up and back risers. To make things work on my 2007 DL650 ABS I had to install the extended brake line. I bled the brakes from the right side bleeder until no more air came out. After closing the bleeder screw and the master cylinder, the brake lever goes all the way in. I have air in the system some where.
My next move is to bleed from both the right and left bleeders. However, when I disconnected the old brake line, the right side line to the ABS unit also comes off. I must have gotten air into that line. If bleeding from right and left sides does not fix my problem, there may be air in the ABS line. If so, how do I get that air out? I am done for today and I tied off the brake lever in an operated position. I am hoping the air will work its way up to the master cylinder.
Can anyone give me some suggestions?
