1 - 14 of 14 Posts
I'm in Guelph and doing a bearing replacement. Is there anyone nearby who would loan the 6 point tool for removing the top yoke?
You can email me at brucedwilson at gmail dot com.
Cvbruce
Or make one from a 1" pipe nipple (if I correctly remember the pipe size). Make it with two tabs. It'll be slightly small, so squeeze it in a vise so it is slightly oval and the tabs fit into the slots on the lock nuts.
flat head drift and a shot mallet... if you cant get them off that way, they were overtightened....
That, or a C-wrench (I think that's what they're called...). The things your dad used to adjust spring preload on those ancient twin-shock bikes.
Can you measure the OD of the nut? I have a bunch of different wrench sizes and I'm not too far from you.
Glenn
What Kinda Bike Is That?
Yeah, inch-'n-a-quarter, not one inch pipe nipple.
The hammer & drift punch will probably deform the tabs on the lock nuts. On my bike there wasn't room to swing a hook spanner. Maybe cut part of the handle off a hook spanner and hit that with the hammer.
Yes, it will. The metal is fairly soft.
You could probably swing a conventional wrench if you removed the fuel tank.
Anybody know the actual name for that 6 fingered socket thing?
Part number 09940-1 4960
Steering stem nut
wrench socket
It's a pin wrench socket. They are special tools for the right diameter.
Probably the best you could do would be a pin wrench. Spanner = wrench in British English.
Steering stem nut
wrench socket
There are two pieces. From my Ron Ayers invoice:
09940-14911 STEERING NUT SO 1 $57.50 $57.50
09940-14960 SOCKET,STEERING 1 $69.17 $69.17
'Pin wrench socket' - thanks. I have a few of the spanners (Canucks are trilingual; both englishes and french :bom_laugh4:) lying around and I offered them to the original poster.
Glenn
1 - 14 of 14 Posts
