1 - 16 of 16 Posts
I'm planning to swap out the top brake line with the longer SS line from SV Racing on my new 650 BS in order to switch the bars to the ATV high bars. I'm also planning to install a banjo bleeder on the MC. I've read tons of "how do I bleed my ABS" threads here and collected nuggets of wisdom from them, but I want to make sure that I understand the process in it's entirety and see if I'm missing any helpful tips. Here's what I plan to do:
1) pull out as much fluid as I can from the MC with a turkey baster
2) loosen the banjo bolt at the distribution block on the lower triple and drain out any remaining fluid.
3) Remove upper line and install new SS line with banjo bleeder at MC.
4) loosely install lower banjo bolt at distribution block but don't tighten down.
5) fill MC with fluid and pump slowly until fluid starts to come out of fitting at distribution block (to prime the new line), then tighten down this fitting.
6) put tube onto bleeder nipple on caliper and run it to a jar with fresh fluid.
7) Crack open bleeder nipple at caliper and pump brake lever until air is purged from plastic tube going to fluid reservoir.
8.) Bleed brakes with Mity Vac from banjo bleeder at MC.
9) Repeat on other caliper.
10) zip-tie brake lever down overnight to purge any remaining air.
Notes/Questions:
- The bike is brand new, so I'm not concerned with purging/replacing all the fluid- just getting the air out of the system. That said, I'm gathering from other threads here that it takes a LOT of purging to get all the air out of the ABS system so I'm guessing I'll end up purging most/all of the original fluid. Any suggestion on how much fluid I should buy?
- Is doing all the bleeding from the MC the recommended way, or should I first bleed with the Mity Vac from each caliper, and then do a final bleed with the Mity Vac from the MC?
- Any other helpful tips you care to share?
FWIW- I've bled brakes (both car and moto) the "old school" way before, but I haven't used a Mity Vac before, and I haven't done it on a bike with a banjo bleeder on the MC (or with ABS) before.
Thanks,
John
Maybe someone can correct me if I am wrong, but I think if your goal is only to bleed the air and not replace all of the old fluid, then you wouldnt want to empty the MC before you start bleeding. I believe that is just a shortcut to replacing all of the fluid.
Edit: actually I think you are emptying it to swap the line out, so nevermind :)
I was under the impression that it'll all drain out if I pull the hose off, so I might as well get as much of it out first as I can. I suppose I could just let it all drain out of the lower end of the hose at the distribution block.
If this isn't the case, and I can pull the hose off without completely emptying the MC, that would be nice but I don't think this is the case.
No, I believe you are correct, I just somehow skipped over the line replacement part of your post and thought you were just bleeding air.
Someone needs to make a video of this process. I did it recently myself and it wasnt hard but there are so many posts describing the process that a simple video would be much easier for newbies to digest.
Air bubbles rise, so bleed from the bottom up. Calipers, distribution block, master cylinder. I haven't used the banjo bleeder on the mc, but if it doesn't seem to work, be patient. Take your time and keep bleeding. It'll get the air out faster than bleeding without the banjo bleeder. You can clamp down the brake lever and let it sit overnight to get remaining air out. Another technique to get the last air out is to pry the brake pads away from the discs. This gets the pistons back into the calipers and forces air up the system. Pump the brake lever several times, and you might find firmer brakes.
To clarify what I think you're saying- suck fluid from the banjo bolt at the MC with the Mity Vac, thus drawing fluid from the bottom (caliper bleeder) upwards. Or are you saying to bleed with the Mity Vac first at the caliper, then at the distribution block (not even sure how I'd do his) and then at the MC?
Thanks. Great tip.
JPK,
I would skip the 1) first step if u dont need to drain the fluid;
I would swap your step (9) and (8 - finish bleeding at the caliper on both side first before going up to the top.
keep an eye on the fluid. Squeeze the brake lever as u tighten the hose to distribution block on the final half turn to assist purging out the air.
last time i used this procedure, i wonder that all the fuss was about bleeding the ABS line- and i have done it the wrong way a couple years back - it took insanely long amount of time and fluid to get it to work. In fact there was hardly any bubbles at all this time.
another question, have u thought of when u might be doing this - on the old bar or new bar - i would do it when the old bar is on - any mess on the old bar will not transfer to the new.
cheers
JPK,
Makes sense, and is easier this way.
This is the part I'm most curious about, as the whole Mity Vac/banjo bleeder concept is new to me. In "old school" bleeding the fluid would flow from the MC down to the caliper. It seems to me that small bubbles would be "swimming upstream" as they try to rise up while fluid is flowing down. It makes conceptual sense to me that if fluid was flowing up from the caliper to the MC, the whole bleeding process would be quicker and more thorough. For this reason I'm wondering if I should bleed from the calipers at all, or do all the bleeding from the MC banjo bleeder. Obviously I'd still want to do both "circuits" by flowing fluid up from both calipers, but I'm thinking that the fluid should always be flowing up from a caliper to the MC to take best advantage of the banjo bleeder. I'm not clear on the purpose of flowing fluid down from the MC to the calipers, only to then reverse it and do the final bleeding with fluid flowing in the opposite direction.
Great idea.
Hopefully mine goes as smoothly! :thumbup:
cheers
I was planning to do it on the new bar, but your logic makes perfect sense. I'll definitely do it on the old bar. This is all part of my "handlebar extreme make-over" with ATV High bars, Oxford grip heaters, and Barkbusters. I'd rather not get brake fluid all over all the nice new shiny bits.
Thanks for all the suggestions.
plus u will then have the longer line for the new bar.
your suggestion as to not to bother with the caliper may work - i just instintively bleed furthest away from the mc and work my way back towards MC
I've heard conversation that suggests pushing the fluid up to the MC from the bottom. As you've remarked. the air wants to rise so why not just force it out the way it wants to go.
Bikes with ABS might be more of a concern due to the pumps.
When we did a couple BMW 800 ST's we had a 911 to work the pump and make things right.
Unlike NyMe, I've not been pleased using the MityVac. Working the lever and opening the valve was the way I ended up doing it.
Speed bleeders are supposed to be a good thing too.
I'm surprised to hear that you didn't like the MityVac notacop. My first bike I always bled the brakes manually, then after reading up on it I figured I'd give the MityVac a try. So much easier IMO, and I didn't need the help of anyone. I love how you pump it up, crack the bleeder valve loose, and watch the fluid flow into the reservoir. What didn't you like about it, notacop?
NyMe, I guess I never got a really good seal on the valve or it leaked around the threads. I didn't get the magic flow you describe or I'd be a believer!
It was a nice Christmas present though.
Maybe I'll have another go. I haven't bled the brakes on the Wee since I got it. I should even buy a new can of BF.
I learnt at school that air bubbles rise through a liquid. Maybe my science teacher was not telling the whole truth. :surprise:
I had a Suzuki Marauder some years ago and found I couldn't get all of the air from the brake lines.
My eventual solution was to unbolt the caliper and raise it to the same level as the master cylinder. Worked perfect.
A friend of mine had a similar problem with a trike.
We raised the front wheel (with a chain block) and propped it on some wooden boxes so the caliper was level with the master cylinder. Success :grin2:
I wonder if something similar would work for you.
1 - 16 of 16 Posts
