Alright so update on this problem.
After performing some maintenance and trying to eliminate all possibilities regarding this oddity, I noticed a bit of dripping under the bike. Figured it was chain lube y'know.. Fresh chain. Cleaned it real good. Maybe I added a bit too much lube so I ignored it. Took it for a test ride and noticed immediately that the bike felt more bouncy than usual. It was a short trip to a close by store so I gave it a good test run to see how the new sprockets and chain felt and for any adjustments on the chain. Got home with no issues. Next day I noticed the oil spot again. Noted it was a little further in from the chain, but figured maybe the excess got flung and its just dripped from that.
Wiped it off the ground, and left it. Came out today.. It had dripped more. Which it shouldn't. 48hrs with the bike sat, that lube should be a bit more sticky. Not runny like this.
I felt around the shock and discovered oil on the bottom. Grabbed a couple pictures so you can see what I saw. The top of the shock is dry. So it has to be coming in from either just above the spring or somewhere in the shaft I'd wager? I have no idea where the oil is stored in a shock though.
Does this look like a leaky shock to you?
Sasquatch has been contacted. Waiting to hear back.
