So I was driving my 2007 wee to walmart in the 105 degree heat, bike running fine, not over heated. Stopped in the parking lot, turned off, went in for about 15 minutes, came out, bike turned over for maybe two or three cycles, and then died. Haven't been able to get it started again. When I turn the key, everything comes on like normal, the gauges sweep across the screen, seems likes its turning over from the starter forcing it to, but no ignition. I had the battery tested which came back that it was fine, put it on a charger over night, still wont start. I took the fuel line off the metal piece coming out of the tank and when I attempt to start the bike, no fuel comes out, which leads me to think its a fuel pump problem?
Help :x
Help :x
