Are you looking at a DIY project or ready made?
Is garage space limited wrt foot print?
Fold up feature is cool, but only 600lb capacity. Dl1050 with a tank.of fuel is pretty close to that.I'm also in the market for a bike lift table. Looking for something on the lighter/mobile side, so I can easily move it out of the way when not in use. Thinking of going with this Kendon Lift
The Titan 1500 air actuated lift. There was conversion kits available also to convert from air/hydraulic to electric/hydraulic. It was expensive though.Is there some current near equivalent to your titan? The ones I see on their site have the same lift height as the HF
Tables are one of those things you'll kick yourself in the ass for not buying one sooner. Once you use then there is no going back. Heck, I don't even bend over anymore to check the oil level or tire pressure. Bike goes on the lift and the work comes to me. To me crawling around a cold floor working on stuff is not exercise its, punishment.I work from the floor. I plop my arse down on a big rubber mat and start working. The exercise does me good. Tables are nice, I’m sure. Jeez, they sure are expensive.
Maybe Some day.
They also have a 1000lb capacity lift for only $100 bucks more. I do worry about it being a little too narrow, but it looks like the base footprint width isn't much narrower than the Titan 1000 series lifts. For me the lighter weight and ease of storage/portability of the unit is higher up on the requirement list. They also sell service trays, oil drain pans and other accessories for the lift. If I had the space, I might consider the Titan SDML 1000 XT, but sheesh that's about $1k more than the Kendon.Fold up feature is cool, but only 600lb capacity. Dl1050 with a tank.of fuel is pretty close to that.
Buy once cry once!They also have a 1000lb capacity lift for only $100 bucks more. I do worry about it being a little too narrow, but it looks like the base footprint width isn't much narrower than the Titan 1000 series lifts. For me the lighter weight and ease of storage/portability of the unit is higher up on the requirement list. They also sell service trays, oil drain pans and other accessories for the lift. If I had the space, I might consider the Titan SDML 1000 XT, but sheesh that's about $1k more than the Kendon.
Nah, if it saves me $1k, allows me to lift and work on my bike securely while standing or on my garage roller seat, it'd put a smile on my face. No tears from this dude.Buy once cry once!
I've seen a few of those before, but not really worth it when you can pay around $450 for a brand new HF lift.If a person has to maintain more than one motorcycle then I can see the possible need for a table lift. However, if you only have the one motorcycle, personally I don't think that it is worth the expence of buying a ready-made work platform.
There are many other inexpensive and some expensive DIY options as an alternative to ready-made.
Examples of DIY options: DIY Motorcycle Lift: 8 Ideas to try out, How to make your own DIY scissor lift with plans | Woodwork Junkie, Motorlift, How To Build a Home Made DIY Motorcycle Lift, TECH: Build a DIY MC Lift/Bench, Homemade Wooden Motorcycle Lift - HomemadeTools.net and WWII wooden motorcycle workbench - Global Dimension to name a few interesting DIY ideas.
