I like mine in my line of sight. Mine is mounted on a Tourtech vibration dampened mount. I've been using this arrangement for over 8 years.I'm about to order a RAM mount, but I have several choices of where I will place the mount (mirror screw, handle bar, above console, etc...). Why do you like where yours is, or what do you suggest?
That won't put the GPS above the instruments. Also, the longer the arm is and the farther it is from vertical, the more vibration transfers to the screen.I use a motorcycle clamp ball, part# RAM-B-367U. It replaces one of the handlebar mounting bolts. With an arm attached I can move the GPS to any position I need to.
One mount on either side of the handlebar clamps. WIth the 6" arms you have lots of range of positioning.Does anyone have two Ram mounts with arms installed on their bike and have a tank bag as well? If so, where do you mount yours?
