After far too many hard miles on my clutch, including silt mountain ascents, wheelies and dune riding, I've finally got to the point where the clutch is slipping nearly every ride and I've maxed out the adjustment at the clutch pushrod. I've gone through all the adjustment checks from the service manual and had two oil changes since this problem began to appear, narrowing it down to the plates. While everyone says these clutches are hardy, I think my less than ideal clutch use has caught up with me at 50,000 miles.
With that said, is there a preferred brand for clutch plate / steels / spring replacements? OEM doesn't seem bad quality wise, but I've burned it out once and I hope to get a good 100k miles more out of the bike, so if there is another company out there with slightly better build, I'd pay a premium.
If anyone can weigh in on aftermarket or OEM clutch replacement performance, I'd really appreciate it!
Thank you!
Thank you!
