1 - 1 of 1 Posts
Do my best work at nite. Just finished installing Genmar up/back risers on the Wee bike. Had to fiddle a little with the front brake line to allow for a little slack and all is well. The throttle cables were tight so an easy solution was to turn the throttle housing a little so the cables are now in front of the brake fluid res instead of crossing over top of it.
And my fav. A Kisan headlite modulator. Tis trully a plug an play item. The simplicity of the modulator is actually quite scary. Only 4 real parts to deal with. The master modulator, it' slave for the other lite, a wire joining them and a fibre optic lite sensor to mount facing up which plugs into the master modulator. All farkles should be this easy to install. Thank you Kisan Technologies Inc.
1 - 1 of 1 Posts
