I've not had this issue before from balancing beads. My first thought would be that the tire has an internal defect. I would occasionally see this back when I was working on cars daily. The common thing was to remount the tire on the wheel backwards to see if it pulled the other direction, which would indicated a defective tire. I would also check the rear tire alignment.
