ok, I posted this in another thread, but I am now seeing it is 6 months old, and you would have the scroll a couple pages to see my problem.
my post:
I seem to have picked up some bad gas while traveling through Ecuador. The problem started about two weeks ago with some major bogging on low tanks and full throttle grips. After trying some STP fuel treatment, the problem did not improve. I drained the tank this morning. I found some water in the bottom. I would guess it would amount to about a 1/4 of a coffee cup. The tank is about drained as much as I could, and now sitting outside to air and dry. Should I put in rubbing alcohol after? My old man said that would be a good idea.
I found tiny amounts of dirt and grime around the fuel pump. Should I be worried about this? Do I want to disassemble the pump to clean it and the filter?
What will be the best way to ensure all the water is out before putting the tank back on? I dont have access to HEET down here, nor a Vstrom manual.
Thank you for your time.
:headbang:
