Aux Fuel Tank for Extended Riding
4998 Views 22 Replies 16 Participants Last post by  Gert
Automotive tire Motor vehicle Automotive design Audio equipment Bumper
2014 DL650A is my ride, and after the normal farkles I had the bike just about perfect for
adventures. I have had it all over the lower 48 and up into Canada, and generally have loved it.
My one complaint is that when I am touring with my buddy on the interstate, especially out west. We cruise at a speed that makes my range significantly less than his.
Running at low speeds the 650 is very fuel efficient, and I out-distance his bike. However, at the speeds of western interstates, mpg drops off precipitously.
I considered just adding rotopaks, which I did, but in the end that still forces me to stop when he is going strong.
I've seen lots of solutions, but none that really solved my issue the way I wanted.
So I plumbed in an aux tank.
I was able to do it without modifying the main tank in any way. I push fuel through the vent tube when running down the road, and when I switch it off everything vents as normal through the charcoal canister. I accomplished this with the solenoid valve next to the fuel pump.
I am sure that some people will have fire risk concerns, but it is all sealed and made from very durable materials that are all fuel rated. Under normal riding, I don't use it, so it is essentially just a 3-gallon blister in the evap system, but on long straight-up rides on 85 mph roads it gives me at total of 8 usable gallons of fuel, and that lets me outdistance my buddy.
I ran the electric through a relay and switch via the Eastern Beaver block, and it really works well. The transfer rate is about 6 gallons per hour, so I turn it on in 10 min intervals to keep the bulk of the fuel in the main tank.
The only downside is that I get questions every time we stop somewhere.
Wheel Motor vehicle Tire Automotive tire Hood
Motorcycle Vehicle Automotive lighting Automotive tire Motor vehicle
See less See more
3
  • Wow
Reactions: 4
1 - 20 of 23 Posts
I like the ingenuity of it and you were able to solve your problem with range now. Yeah, fire would be a concern in an accident but your already aware of that. Questions? I would imagine every time you stop you get questions. I'd put a flux capacitor or maybe a radioactive symbol sticker on it somewhere just to keep people guessing. I'd have fun making up some b.s. story on what it is to people.
  • Haha
Reactions: 5
Nice work!
When I was building my slave tank last year, I toyed with the idea of a fuel pump to transfer the fuel and it became overly complicated. Instead, I went the much simpler route and connected the slave tank to the main tank vent, so fuel is pulled in vs pumped or by gravity. No pumps or electrics to worry with and super simple to make quick connect. I can have my slave tank on/off the bike in seconds.
Reactions: 5
Nice work!
That is certainly a simpler solution than mine and was similar to my first go.
I tried the gravity feed/siphon solution but found that it left about a gallon in the aux tank. It is possible that the GS tank seals better and as a result can pull more fuel than my Glee.
I also found that I had leakage when sitting still at the main tank filler once the feed started. Everything has trade-offs, and I added complications in exchange for more positive control.
Reactions: 2
Doubtful that the GS tank seals any better than any other tank. For me no leaks and slave tank is totally exhausted save for maybe a cup or so if fuel that once the end of the hose becomes uncovered the vacuum breaks.
Some on the east coast may wonder why people do this. If you have ever made a cross-country trip across the western U.S. you know exactly why people do it. And the questions about how much gas is left when the fuel level indicator says empty don't seem so trivial.
Thank heaven for people willing to give stranded motorists a lift to Baker City Oregon.
Reactions: 4
The other thing you always hear is I’d have to stop to pee before I ran out of fuel. So just stop at a gas station and do both. While this is a good plan personally I’d rather have plenty of fuel and stop where and when I want. I’ve seen enough gas stations to know what they are all about.
I can carry a bunch of fuel on my GSA coupled with the 3+ gallon slave then. Most of the time I can top up in the morning grab some snacks and not have to worry about anything but riding the rest of the day.
Reactions: 2
Did you consider a more stealth approach where you incorporated the tank inside either a top box or a side case?
I considered it but ultimately I like the crazy mad max look of the thing. I haven't had any legal trouble, so a few questions from people at fuel stops is a small price I guess.
Reactions: 2
For me it is some of both, In Nevada where I used to live fuel stops could be few and far between. Out west, traffic can really move and the Glee while offering great economy at 60-65 starts to get thirsty at the flow of traffic out west (normally 80-85 true). My 6'6" height and the paniers camping gear etc don't help the fuel consumption.
I don't like to ride slower than the flow of traffic, so while I could slow down and make fuel stops more frequently to cope with some of the distances I prefer this solution.
Reactions: 2
My GS with panniers and loaded with my fat ass are like pushing a sheet of plywood through a hurricane. Normal everyday 2-lane riding even spirited garners 42/44 MPG. Hop on the interstate and keep up with traffic expect a 20%+ drop.
It's no secret motorcycles are about as aerodynamic as cinderblocks. Ad in panniers, big windscreens and its only amplifies the coefficient of drag.
Reactions: 4
I always enjoyed the enthusiasm of Tim the Toolman. If it's worth doing, it's worth over-doing. I have made many things in the shop that lots of people would consider overkill. But they did the job and they made me happy.
That is the most sophisticated aux fuel tank I have ever seen on a motorcycle.
Reactions: 5
Pull up beside a Tesla.Tell the driver it converts gasoline to electricity;& that you get 125 miles per gallon.
  • Haha
Reactions: 3
My airplane doesn't have as complicated a fuel system as this Binford 6100 aux fuel tank.
  • Haha
Reactions: 4
Wow, looks like you are riding with your own alcohol still or a bomb attached :)
Wonder how much trouble you might have crossing the border?
  • Haha
Reactions: 3
Wow. Pure quality, no corner cutting, and crazy attention to detail. I'd use that on my resume. My hat is off to you and your skill.
Reactions: 2
A single wheeled trailer with two rotos seems an easier solution.
Nice work, just don't linger around any federal buildings !
  • Haha
Reactions: 2
Says the guy named, "nuke".....
A lot of us in the Long Distance/Iron Butt/Rally riding community use an aux tank. I have a 5.35 gallon gravity fed tank on my Tenere. On my Strom I cut up the stock gas tank and expanded it to hold 7.3 gallons total. Rotopax are also popular.
Reactions: 1
1 - 20 of 23 Posts
