Hey all, did a quick search and didn't find anything so a quick question.
I did alot of upgrades to the bike with Jim and EB fuse box and switches and powerlet plugs and wiring and added a suprabrake from Jim as well and wired the coocase S48 into the fuse box as well.
Anyway, bought the bike with cruise already installed and after installing everything the cruise stopped working.
So I am starting to think I jacked cruise up somehow during all the installs of other items. So went through all cruise directions and Roy's CC Install document and forums on cruise installs. Took the bike apart checked the wiring the vacuum piping everything, can't find anything. I even rewired the cruise to the old fusebox with the old switching wire from the tail that the PO had on the bike and it still wouldn't work.
Although I did notice that with the old switching wire I could turn the cc on and off and with the current tail adaptor with fuse box from EB it stays on all the time when the bike is running but I digress.
So I switched everything back and resolved that I would be without cruise because I just couldn't figure it out. I read through the document and saw where someone said you can't attach any kind of specific brake changing lights into the circuit or the cruise will stop working. There was an explanation but I couldn't totally understand it.
So I took the suprabrake out of the circuit and now the cruise works again.
That's great but I really like the suprabrake I got from Jim, and if I am forced to choose I will take the cruise.
So for all you wiring geniuses out there have you figured out a (hopefully simple) way to get around this issue, I can't be the first?
Thanks in advance,
David
