I agree, my course of action is to get the smallest shims available to try to open the gap as much as possible while I prepare to rebuilt the cylinder head
I agree, my course of action is to get the smallest shims available to try to open the gap as much as possible while I prepare to rebuilt the cylinder headI really wouldn't ride it like that. There's a high chance you'll stick a valve through the piston.
Yeah, I didn’t understand those OP comments, either.TDC is when you have the biggest gap. If I understand you right you say there is more space when you are not at TDC. This is impossible. Which to me can only mean that you need to look again to find the true TDC.
thanks for pointing this out clearly, I will double check the service repair manual and make sure I'm following the procedure.TDC is when you have the biggest gap. If I understand you right you say there is more space when you are not at TDC. This is impossible. Which to me can only mean that you need to look again to find the true TDC.
After reviewing the instructions, I followed them correctly as far as aligning the indexing mark with the F| for front and |R for rear in the inspection hole but I dont recall my cams being in that position, will double check this afternoonTDC is when you have the biggest gap. If I understand you right you say there is more space when you are not at TDC. This is impossible. Which to me can only mean that you need to look again to find the true TDC.
This is expected when you don't remove a spark plug before trying to rotate the motor.There are some super sticky parts of the crankshaft rotation where I can hear what sounds like decompression happening in the front cylinder (my problem cylinder).
WHAT?!Camshaft(s) could be bent!
You are getting way ahead of yourself there. Please review the mechanical timing of the parts. The proper mark on the crank must be coincident with the marks on both cams as pictured in the manual. If you have lifted the cams out while they depress the valves you are in the next orbit of trouble. This job is sequential in an order. When done in the order, there are no surprises in an engine that was running.I agree, my course of action is to get the smallest shims available to try to open the gap as much as possible while I prepare to rebuilt the cylinder head
Roger that, will remove the plugs and hope that eliminates the friction when turning the crankshaft manuallyThis is expected when you don't remove a spark plug before trying to rotate the motor.
Just so I understand, the "F|" marking, when aligned with the mark on the inspection hole, does not always indicate that the cams will be in the correct position? I may need to continue rotating the crankshaft until both the F| AND the cams are in the correct position?You are getting way ahead of yourself there. Please review the mechanical timing of the parts. The proper mark on the crank must be coincident with the marks on both cams as pictured in the manual. If you have lifted the cams out while they depress the valves you are in the next orbit of trouble. This job is sequential in an order. When done in the order, there are no surprises in an engine that was running.
So it seems as though I interpreted the instructions in the service manual incorrectly. I assumed based on what I read that the cams would always be in the correct position if the crankshaft was in position for TDC. I didn't understand that I may need to rotate the camshaft 360 degrees several times until the cams are also correct.Even the smallest bend on the camshaft? Would cause engine shake/noise like a MoFo....No?
Mike, did you pull the head in question yet? Maybe something is not releasing/binding?
Good luck
Correct. There are two top dead center positions, one for compression stroke and one for exhaust stroke. At TDC on exhaust stroke the cam lobe will be holding the exhaust valve open. At TDC on compression stroke, valves will be fully closed and this is the position for adjusting valve clearance.Just so I understand, the "F|" marking, when aligned with the mark on the inspection hole, does not always indicate that the cams will be in the correct position? I may need to continue rotating the crankshaft until both the F| AND the cams are in the correct position?
You are correct, yourself and others have enlightened me to something I missed in the manual where I may need to rotate the crankshaft 360 degrees several times until the cams are in position. They were not in position, unfortunately I did remove the cams while they were pressed against the valve tappet, but I was super careful and took pics to ensure they were reinstalled as they were removedSomething is not in its position if there is no gap at TDC. Double check your manual.:
- Are the intake and exhaust cams in the proper place (not reversed)? They are marked IN and EX. Not trying to insult you, but just looking for clues.
- Are you sure the cams are at the proper position when the flywheel is at TDC?
- Are the cams aligned with the mating surface of the head as it is specified?
- Are there the proper number of cam chain links between the marks on the cams?
Yes. Understand the sequence. The crank can go round and round but it is only in the correct place when the hash marks on the camshafts coincide with the correct mark on crank rotation. At that point the crank must not move again . When the cams are removed and replaced they will reflect the same marks aligned with the gasket surface as before. Any discrepancy with this alignment on re-assembly indicates a part out of sequence.Just so I understand, the "F|" marking, when aligned with the mark on the inspection hole, does not always indicate that the cams will be in the correct position? I may need to continue rotating the crankshaft until both the F| AND the cams are in the correct position?
There is nothing in the assembled parts that would bend a hardened camshaft without being involved in a total wipeout.Even the smallest bend on the camshaft? Would cause engine shake/noise like a MoFo....No?
Good luck
Yup first time! I bought the bike sight unseen for $1500 from a friend based on the reputation for longevity.Well, it is your first time I assume and you are at least trying.
I probably made a lot of mistakes, but sometimes the you have to learn the hard way. We all have different circumstances.
All the info you need is probably here already.
DL650 Valve Adjustment Notes and Tips
This zipped Word document contains several pages of notes that I prepared after completing the first valve adjustment on my DL650. It is a compilation of suggestions from other posters and my own tips and observations. It is meant as an adjunct to the Workshop Manual, certainly not a...www.stromtrooper.com
Suzuki V-Strom DL650 Valve Check and Adjustment tutorial - CircleNZ
Our simple step by step illustrated tutorial showing you how to make a valve check and adjustment on a Suzuki V-Strom DL650…circlenz.co.nz
