1 - 11 of 11 Posts
I have a like new 2007 non ABS and a guy who has a new 2011 ABS bike wants to trade me wheels. Heck, I have a silver DL650 so why not silver wheels? Is it just a straight across trade-out or will it be a pain in the butt? Where are the ABS sensors located? Will we have to keep brake disks, etc. seperate to our bikes? Any help appreciated. Thanks, Bucky
Wheres GreyWolf? He's the man who would know.
Pat?//
2007 and later ABS are interchangeable.
2007 and later are interchangeable.
Does a non-ABS bike have the ABS rings? If not, make sure he takes his off before giving you his wheels.
The question was about ABS bikes but I added that to my answer to avoid confusion. ABS and non ABS wheels have different part numbers and those parts do not include the ABS sensor ring.
That's what I thought. Check the OP again, he said he has a non-ABS, and wants to trade with an ABS.
You're right. I read it wrong and completely missed the "non" even when looking a second time. The non ABS wheels still got a larger hub diameter in 2007. ABS and non ABS have the same discs. Maybe the non ABS wheel is just not drilled and tapped for the sensor.
I apologize for the mis-read and hope it didn't cause a problem.
Discussion Starter · #8 ·
All information received! Thanks for your input guys! I figured they were different but just wanted to make sure! Bucky
Since this is answered, I am going to divert a little.
What about 1000 over to 650?
I have a 2006 DL1000 and a 2007 DL650 Non-Abs that I would love to have a set of TKC80's mounted on spare rims to interchange if I wanted to do an off asphalt excursion.
Mike
Mike
The rears are the same on all DL1000s and DL650s from 2004-2006. DL650s changed in 2007 for both ABS and non ABS. The fronts are totally different. You're out of luck on both ends with that year 650.
Thank you sir
Mike
1 - 11 of 11 Posts
