When I made mine, I never took measurements......am working on a template to make my tool. I drew this, so I could print multiple copies.
Seem correct to you?
ty...
The OEM tool has an outer diameter of 45mm. The pins are inset 1mm, pin thickness is 2mm x 4mm lengthwise and they are inset 2 mm from the inner circle, which is 33mm.am working on a template to make my tool. I drew this, so I could print multiple copies.
ty...
