Just wondering how long your spacers were, these springs are SHORT!
What Kinda Bike Is That?
For the sake of comparison, a set of Sonic Springs, (.90wt), measure 16 3/4" long. The spacers for the springs, (installed in a 2007 DL-650), measure 3 7/8" long, (the spacer length allows for washers and the fork cap; about 3/4" of pre-load before the cap is installed.).
(Maybe this will help? :confused: )
B.
B.
Thanks Barry. It just might help with the baseline. The Race Tech springs are 12 1/4 long:confused:
Ex- moderator
Measure the spacers carefully, use a tube cutter and then file for accuracy. Start off with your preload adjusters screwed all of the way out..
Is the bike supposed to sag with no rider on it?
That was informative, thanks!
I am working on my bike in the same area as you; suspension. I am trying to get to a place where I can "demystify" for myself and come to a "second nature" understanding of what needs to be done for ME, (and my type of riding.).
Part of that process is how I set the bike up for this Spring. I know what the bike will do at one extreme, (set too stiff), and I wanted to know what the bike would do at the other extreme; set up very soft.
Currently, the front has the OEM springs and 10wt oil. I ended up having a sag of 50mm which is about 15mm-18mm too much. My rear shock is a Hyperpro. I had too little pre-load in it and not enough rebound, (soft).
With the above setup, I could seriously blast over frost heaves and rough roads at high speeds. But, that's with the bike dead, straight up and down. (Check out the section of this video, http://www.youtube.com/watch?v=9sLO5MsETGM, between the times of 1:04 > 1:06. I am riding at about 60+mph and loving it.). If I throw the bike into a sweeper, I am immediately on my "knees" saying my prayers; I've got a handlebar full of bike. If you add a good compression dip into that sweeper, or some frost heaves, I got some serious stuff going on! In very sharp corners, the bike wants to stand up; twice I have skidded up on a sidewalk on a turn that previously, I could lay the bike waaaaaaayyyyy over and track nicely through. Yesterday, while riding a couple of logging roads, I lost it twice while coming around turns; the bike just wouldn't track in a "groove" as it normally does for me, (I even stopped the bike, got off of it, walked around it a few times to see if anything had come unbolted or was leaking out of the bike to make it handle so poorly!).
Chalk it up to "in-the-field-testing". I just plain want to know what the extreme settings feel like and what they do to the bike.
As a temporary fix, (I just came back from a spirited test ride.), I cranked my fork pre-load all the way down; I am maxed out. I also added pre-load to the rear shock and stiffened up the rebound 5 "clicks".
After work tomorrow, I am going to slide out the OEM springs and slide back in my Sonic .90wt springs so that I can gain some pre-load adjustment back. I will also change to 12.5wt fork oil. I have ridden with this setup before, and it is a nice "middle-of-the-road" setup for me, (about 185lbs all geared up.).
BTW, I also have Race Tech Emulators installed with 1.25 turns on "yellow" springs.
