Anyone ever used an accelerometer for their brake lights?
4.5K views 15 replies 10 participants last post by  FredBGG
There are several products out there with deceleration activated lights that will come on when engine braking.
Not a bad idea.
I have my rear brake lever setup so that even just a little bit of pressure trips the switch on the peddle even if there is no actual rear disk braking kicking in yet. I will feather my rear brake pedal when down shifting significantly to slow down.
I also have a long steep downhill in my commute. For parts of it it's enough to just down shift on a bike when cars would also be braking. That is another time I will feather my rear bake lever to send a signal to someone behind me.
I bought a vololight but I haven't installed it yet.
My problem is that I usually ride solo so I'll have to enlist my girlfriend to drive behind me in order to tell if it's working correctly.
IF you have a rear brake light enhancment it's a good idea to wire an indicator to your dash so you can see what it is doing and know it's working.
You could make a quite elaborate even wearable accelerometer brake light system using an Intel Arduino and a Flora accelerometer.
Would be quite possible to program some custom signalling too.
Even tap into the turn signal of your bike with a wireless module for the arduino.
The Arduino is a mini wearable computer.
