1 - 2 of 2 Posts
If you do could you look down inside the Vee shaped engine mounts on both sides and tell me which way the little coil wires are plugged on? looking down from the top the coils are kinda of tear drop shaped, which colour wire goes to the pointy end? Thanks guys Tim.
Coil wiring
Duck, On the bikes left side, front cyl coil, the white w/blue stripe is on the pointy end. Right side ,rear cyl, black wire is on the pointy end. Hope this helps. Tim
1 - 2 of 2 Posts
