1 - 1 of 1 Posts
Just posting a few picks of my Rostra Cruise install. Found an easy way to mount the cable. Drilled and tapped 10-32 on a small bracket that hangs out from the TB bracket. Pulled the front TB arm from the rear. Mounted the servo at the back end in front of the tail lights. I pulled the connector pins out of the plugs and soldered the CC wires to them and pushed them back in. Nice a clean and no wire cutting and heat shrinking, except for the switch wires.
DG
1 - 1 of 1 Posts
