1 - 3 of 3 Posts
I have read several posts on installing the Symtec Grips and posts on the connector by the radiator for wiring the OEM grips. My question is: Can I take the power from this connector to power the grips directly or do I use it to trigger a relay and power the grips directly off the battery via the relay?
Direct is fine. It's direct for OEM.
Discussion Starter · #3 ·
Thanks Greywolf. I was not looking forward to adding another bit of electrical complexity. Simple is good.
1 - 3 of 3 Posts
