I've had this bike a week and LOVE IT! I thought that I've read somewhere on here the alternator output for the '09 @ 5K was 145 W? If anyone could hook me up with that info I'd appreciate it. I've done more Googling with no results than I care to think about. Thanks in advance.
The 05 has a 375 Watt output alternator (26 amps at 14v). The bike uses approx. 200 watts to operate, leaving you roughly 175 watts or 12.5ish amps.
I installed an EB low beam (1 headlight) cut off, which will give you another 55 watts or 4ish amps to play with.
I have verified these numbers using an inductive amp gauge, and have no problem running my various accessories including heated gear.
Cheers
'08s and later have another 25W for a 400W total @ 5000rpm. My 07 seems to have about 125W to play with though rather than 175W.
ABS would take some of that wouldn't it? Just curious.
Yes, it does. And when activated, it takes a huge amount.
