My 2017 Wee had a voltmeter so it was easy to check how the system was handling the load.
As for draws: Several suggestions have been mentioned, things like changing the high draw head light to a low draw LED bulb. This change alone can make a difference if you are using heated clothing.
Remember that when looking at load to consider that things like a heated 90 Watt jacket only draws 90 Watts when its running at 100% heat, something one rarely does. Same goes for heated grips. I estimate that my heated gear actually only ran at 20 to 30 percent of power most of the time with only short bursts at 50 percent. Over 50% for any time at all and I was overheated! On my '05 Wee with two head light bulbs in cold weather I would just turn off one bulb which gave me an extra 45 Watts or so to work with. Just for fun put your hand in front of your head light and see how hot your hand gets!
Some over think this and say things like turn off your heated gear when you stop at a intersection or whatever. While this does lighten the load, its over kill! One of the main jobs of the battery is to handle electrical loads when the output of the charging system is less than the load, as it would be say at engine idle. As soon as you rev back up the battery will be charging back up. In seventeen years of riding Wee's, usually with two of us both with headed clothing and with heated grips I never had an issue with the electrical system being overloaded and got at least five years service out of a battery. Don't over think this!
