1 - 3 of 3 Posts
I am working on a 2008 650 and have disassembled the airbox to remove it from the bike. In the process I broke one of the nipples that connects a hose to the bottom of the airbox. This nipple has an electrical connector on it so I assume that it is a sensor of some kind. It is on the RH side of the airbox when sitting on the bike and has a hose connected to it that joins into a hose below it with a T connector. The sensor is held onto the airbox with two phillips screws. I have looked at numerous diagram of the airbox but cannot find anything that looks like this sensor. Any ideas what it might be? Thanks very much.
It's likely the intake air pressure sensor. It is on the right side of the airbox and has a hose connection along with wire connections.
1 - 3 of 3 Posts
