1 - 6 of 6 Posts
I recently changed the air filter on my 05 wee and when I pulled the old air filter off I noticed about 1/4 cup of what looked like oil in the "pan" the filter sits in. Smelled a little like gas. I have owned the bike for 9 months and just got around to checking out the air filter, (dealer said they changed it), they didn't. It was probably 2 years old, very dirty. The bike has 45K miles on it. Is this normal to find? What is that stuff in the bottom and should I be concerned? It was a stock filter, not a K & N, that I took out so I don't think the oil is from that. Any ideas?
If the bike is on its left side, oil can migrate through the breather and into the airbox.
In more detail. There's a vent from the crankcase into the airbox intended to burn any oil caused by the crankcase being pressurized. (Some gas gets past the rings)
On the DL 1000 in particular , if it lies on it's side with the engine running, engine oil gets pumped into the airbox.
So - three possible causes.
1) Excess oil from the K&N (most likely)
2) Bike's been on it's side
3) Oil droplets cause by crankcase pressure - unlikely as most goes straight into the engine and burns immediately
Pete
Winding her out can increase both oil mist and thr blow by into the airbox
The air filter is such a rip off that most don't change it
Don't worry be happy
Thank you, thank you!
My bike was found with the same issue when I got it with 23K on it. I thought the oil was a bit over filled and attributed it to blow bye. I checked it at 29K and found a bit more of the oil pool in the bottom of the air box.
Now I know why and won't worry about it!
1 - 6 of 6 Posts
