:green_lol:It is a pain but you only have to take it out once.
Just don't screw up and put in another one or you'll just have to do it again in another thirty-thousand miles.
Where do you get that idea from?Do you literally have to take the entire front end / cowling / instrument cluster apart to take the air filter out?!
How much would it take to hire you to come down here and do the maintenace on my bike.Where do you get that idea from?...just remove the gastank, and you can change your air filter; it takes 15 minutes, 20 if you're not in an air-conditioned garage (you need time to sip at the beer).
Really?How much would it take to hire you to come down here and do the maintenace on my bike.
When you're passing through texarkana, let me know. (I'll supply the beer)
Works fine for me too. Been doing it like that a long time. I do take the bolts out of the fairing so it will bend out a little more.UNdo black cross plastic front tank mount cover
Undo front and rear tank mounts
lift up rear put on a block undo hose and electric plug
take off tank by moving it mostly backwards and up
front fairing ends will bend outwards a little to let tank pass
return the same way maybe moving the plastic fairing a little sideways as the tank is inserted.
Once again - Fuel Tank Removal How to, 650 & 1000No friggin way you can get to my air cleaner the way the manual says. Not in any way that I would consider safe to the parts invloved.
