How do i add or change a quote that will show when i post?
Click on the quote button at the bottom right of the post that you want to quote. You can then edit the quote as you want but remember that it's a quote and you should never change the meaning of what is quoted you should simply delete unnecessary text.
You should also post in the correct section of the forum. I have moved this thread to where it should be.
Thanks!
Thanks. I see that u moved my question to the appropriate area. I figured it out though so maybe i should delete this thread.
im still learning how to properly use the site.
