Where would one purchase these rivets if one were to have broken one...That's right. Rack and side panel need to come off. There is a plastic rivet on the bottom. Press the center in to free it.
--BOLT Motorcycle Hardware-- is one place. Suzuki dealers are probably more expensive. Except for two 8mm ones under the fairing, they are all 6mm.Where would one purchase these rivets if one were to have broken one...
On my Vee I can service the master cylinder without removing the side panel or rack. By removing the bolt at the front of the panel, there's enough "slack" to move the panel away from the bike and get to the top of the cylinder. Slip a spacer (large screwdriver handle worked for me) at the front of the panel, and you'll have enough room to remove the cylinder top, add or change the fluid, etc.I can't figure out how to get to the rear master cylinder. It looks like I need to remove the blue side panel, but to do that I also need to remove my rear rack..is that right? Is there a trick to getting to it?
This is what I do. I'd rather take the plastic off but a bolt that holds down the rear rack has been stripped and I haven't got around getting it off.On my Vee I can service the master cylinder without removing the side panel or rack. By removing the bolt at the front of the panel, there's enough "slack" to move the panel away from the bike and get to the top of the cylinder. Slip a spacer (large screwdriver handle worked for me) at the front of the panel, and you'll have enough room to remove the cylinder top, add or change the fluid, etc.
Obviously you need to be careful, the plastic is flexible but not unbreakable.
I use the same method, with a long neck funnel to make sure the brake fluid goes where I want it.This is what I do. I'd rather take the plastic off but a bolt that holds down the rear rack has been stripped and I haven't got around getting it off.
I cover all the plastic up, aim, and poured.
How did you manage to strip one of the bolts??This is what I do. I'd rather take the plastic off but a bolt that holds down the rear rack has been stripped and I haven't got around getting it off.
I have never taken the rear bolt out before so, I am thinking that it has been like that since I bought it. The head looks like someone filed it down - it's truly remarkable. I just picked up a dremel - quite possibly that best tool. That bolt doesn't stand a chance now.How did you manage to strip one of the bolts??That truly sucks. If it is one of the rear bolts, you could try slotting it with a dremel.
The shiny fairing bolts on the other hand - those are made out of soft cheese. I've got two that I've slotted already and three more that need it.
-edit-
To the OP, whatcha needing to get back to the rear resevoir for? Any issues?
No issues. I just realized I flushed the front but forgot to do the rear.How did you manage to strip one of the bolts??That truly sucks. If it is one of the rear bolts, you could try slotting it with a dremel.
-edit-
