ABS Warning light?
1 reading
52 views 2 replies 3 participants last post by  PeteW
#1 ·
2015 model and the ABS warning light has come on. I checked the fuses. Cleaned the wheel sensors and the abs ring on the wheel and it's still showing? So 2 questions. Anything else I can check before the abs pump is looked at? Secondly would an abs motor from the same year DL1000 work on this bike ...as used units seem in short supply.Thanks for any help 👍🏽
#2 ·
You say that you have checked the fuses, but did you confirm that there is power to the fuse socket?
If you don't have access to a wiring diagram, have a look at https://www.stromtrooper.com/thread...com/threads/2013-vstrom-650-wiring-diagram.437044/?post_id=5595411#post-5595411
Try determine whether there is any ABS fault code (ABS blink rate to be translated). Some info worth a look at is shared in ABS See replies #8, #14 & #15. Also have a look at https://www.stromtrooper.com/threads/2012-dl650al2-abs-not-working-with-c00.433426/
A replacement ABS pump is discussed in https://www.stromtrooper.com/thread...tibility-chart.439163/?post_id=5632834&nested_view=1&sortby=oldest#post-5632834
