Good afternoon,
long story.. some what short,
First of all my bike is a 2009 V-Strom 650A
I am trying to disable my front ABS while trying to retain the functionality of my rear ABS. (maybe even put the rear on a switch) I currently have no way of installing the front ABS (Op hacked the hell out of the bike) as the front wheel is off an regular 650 and not a 650A.
The rear ABS is hooked up with a known good sensor and nothing is currently attached for the front sensor, but I do have one. The current ABS codes on the bike are 42 and 45 (front and rear sensor). I took the bike for a quick ride yesterday, it was finally above 0 to do so. Of course the ABS light was on and the rear ABS was not functional. I am not sure if the bike will clear the codes on its own or if they have to be manually deleted? If so I am not sure how to delete the codes.
Also I noticed the a relay located next to the ABS fuse (25/40A ones) is different then the one I have on a spare harness from an 2009 650A. The one currently on the bike is 06Y8D5 vs 0039D5 that is on the spare harness. But they are both labeled with the same G8MS-S23 number.
Any input or questions to help steer this into the right direction would be appreciated.
