1 - 2 of 2 Posts
I took the Vstrom on some dirt and with the ABS it is ok on fireroads and hard packed but in the soft dirt I would like to disable it. There are 2 fuses under the seat for the ABS does anyone know which one or if both need to be pulled to disable it? Does this have any negative effects on the bike other than just not having ABS while fuse is out? Thanks
The ABS valve fuse will work fine.
1 - 2 of 2 Posts
