Is there a way to tell if a DL650 has ABS brakes from the Model number or VIN? I am looking to buy one and the owner doesn't know and he is not in the same location as I am.
Model DL650A on the VIN sticker directly above "Made in Japan"
ABS sticker on the front fender
ABS speed sensing ring on the right side of each wheel inside the disc
He doesn't know if his motorcycle has ABS? That's a pretty basic thing to 'not know' about your motorcycle.
I've seen a number of people who didn't know or thought they had it but did not. I've never seen anyone who didn't know actually have it.
Well, you can rule out ABS if its the blue color in the US since only the grey color got it, but even then it was still an option on the grey.
The other guys gave you good things to check. I haven't seen mentioned about the ABS light on the dash either. It should light up when all dash lights do their self check at startup.
