1 - 4 of 4 Posts
I have an '07 DL-650. I'm installing L.E.D. turn signals in my GIVI V-35 saddlebags.
Im looking for the wire colors for the :
1. Running lite
2. Brake lite
3. Left turn signal and right turn signals
I need to tap into these circuits to power the L.E.D.'s
Will post pic's and story as soon as installation is complete.
Thanks in advance!
Jim
If you peek up inside the storage area under the seat and look at the rear light, the wires you need for the brake light should be right there. I've seen some pics on here about how to take the tail apart to easily access them, but I'm still a rookie to the stroms, so I make no illusions about being able to help.
As for the signals, I can't be much help there either... Like I said, with the tail off, IIRC, you can access the wires pretty easily.
The running light is brown in the sheath of wires running along the left side of the under seat tray. Inside the fender, it turns to gray. The other wires are the same color in both places. The right turn signal is light green, the left turn signal is blue, the brake light is white with a black stripe and ground is black with a white stripe.
1 - 4 of 4 Posts
