3D printed accessory dash 2006 DL1000
1043 2
New member and VStrom rider here. I bought a 2006 V-Strom DL1000 back in August. I had my son design and 3D print a dash for the bike. I wanted a charging port, gear indicator and 2 position switch for driving/fog lights. It came out pretty good, especially the way the gear indicator snaps in like a factory piece.The plastic dash bolts onto the existing cable guide. I cut the hole on the left side into a slot so you can tilt it up to work on the wiring. I had to drill and tap the hole on the left side.
3-pin switch, amazon - https://www.amazon.com/dp/B0774LY1M8
charging port, ali express - https://www.aliexpress.us/item/3256802878599244.html
gear indicator, ali express - https://www.aliexpress.us/item/3256803842430642.html
Wheel Tire Automotive tire Automotive lighting Motor vehicle
Motor vehicle Speedometer Automotive lighting Light Vehicle
1 - 3 of 3 Posts
1 - 3 of 3 Posts
