1 - 12 of 12 Posts
So I've been reading up on the issue of headlight, (or is it starter switches) burning out on previous models due to high current flowing thru them. They apparently are not heavy enough to withstand the power draw. Do current models of 2017+ suffer this same malady? I've read of the various solutions that Eastern Beaver offers and quite frankly it's a lot to take in.:confused:
On a more pleasant note, farkles start arriving today.:hurray:
I'm sure the newer(Single headlight) models would still benefit from a relay, but with half the draw(55W versus 110) problems are a lot less likely. After some problems I put the relay on my 05. Don't think I will on the 18 1000. LED's lower the risk also(Less draw).
If you don't want to use an led headlight, then you could order the EB relay with the H4 plug and find a H4 to H7 adapter.
1 - 12 of 12 Posts
