1 - 4 of 4 Posts
Discussion Starter #2
I did read on here to squeeze the blue tabs on the attachment to remove the fuel line. I have tried this several times without luck.
Try pushing the hose into the tank spigot to ease the pressure on the blue clip, then squeeze the clip ears together. The clip stays on the spigot and the black part comes away so you need to squeeze the blue part only.
When you reinstall the gas line, be sure you push it all the way in until it clicks. Give it a tug to be sure you've engaged the blue clips.
1 - 4 of 4 Posts
