1 - 11 of 11 Posts
UPDATE: I am officially a knucklehead. The bike was in gear and wouldnt start even though I had the clutch pulled in. My vrod doesnt care but I forgot that the WEE has the safety feature kill switch with the kickstand down. DUH!
Guys,
I went out to the garage this morning and went to start the bike. There was a lot of noise so I didnt hear the fuel pump kick on when I flipped the switch. I went to start her and the headlights went dim and the bike didnt turn over. I thought it might have been the battery so I put a trickle charger on it. When I got home from work the charger was green and I went to start the bike. When I flipped the red switch, no fuel pump whine. Tried it again no dice. I removed the fuel pump relay just to check the connections and the connections looked ok. Still no dice. Any ideas? Is there a fuse maybe?
Sean
Did you check the battery cable connections to the battery?
That is a really good place to start your search.
Been there, done that. Welcome to the club!
Ha ha! Doesn't the CHEC dealie come on for Knuckle heads?
No one has had a real problem yet that I can figure.
That sounds like something I would do. At least you were 'big' enough to follow up with an explanation.
Sent from my Motorcycle iPad app
Had a fellow strom rider ride up to me and flag me down in charlotte a few weeks back. There was a wreck a few miles up so traffic was pretty hectic, so I pulled onto the shoulder and he gave mine a good look over as i did the same for him. I got back on the bike and started it and evertime I went to put it into gear it would kill itself:furious:. I turned around and looked at the other stromer and he was pointing at the kick stand, which I forgot to put up:headbang:
1 - 11 of 11 Posts
