1 - 4 of 4 Posts
Hey there, my problem is that the distance between the clutch foot peg and lever is not enough space for my offroad boot. for my road boot (which is more nimble) it's perfect, however once I put on my other boots, it's a pain in the rear to shift. There are 2 holes for adjusting the peg position. mine's on the farther one but still not enough. other experience similar issue? any idea for good aftermarket solutions? Thanks.
I put the fastway pegs on mine, and adjusted the brake and clutch lever to suit, works well with off road type boots.
Discussion Starter · #3 ·
Thanks. so the fastway brand can sit lower than stock, which makes it compensate for the short distance with the lever I take? my boot is size 9 so it cant be that Im the only person feeling cramped in shifting.
Correct, as will the sw motech pegs. The fastway pegs are solid stainless and are stronger. Also much more aggressive grip.
1 - 4 of 4 Posts
