Just wondering if anyone knows where the auxiliary power line and/or the heated grip power is on the non-abs 2009's? Or if this has been covered in a previous post? I found a post talking about the later ones 2012+
Vees and Wees only have heated grip power connectors, no aux connectors. They are behind the radiator top shroud and are usually taped to the main harness. Look for a tiny spot of orange on the harness as a bit of the orange/green positive wire usually stays visible. It's usually easier to find if you remove the black plastic boomerang shaped piece under the left side of the fuel tank.
Hey Greywolf, are those connectors on all model year DL650's? I have an '07.
Heated grip connector, yes. Aux connector, no.
