2007 R1200GS w/ 16,524 miles. All service up to date and brand new Metzler Torrance tires installed on 8/1/22. The bike is in very nice conditional everything works as it should. This GS needs nothing but a new rider. Clean clear PA title in my name ready to transfer.
Bike is located in Chambersburg PA and priced at $7,499.00 cash as pictured or $6,999.00 cash without the paniers/racks and rear rack.
Bikes come nicely outfitted with the following:
• 10/27/20 Flushed and bled F/R brakes with Prestone Dot4 brake fluid at 13,726 miles.
• 10/27/20 Changes the Transmission oil with 850cc of Valvoline 75W-140 full synthetic gear oil @ 10,736 miles.
• 10/27/20 Changed engine oil with Mobil 1 15W-50 @ 13,736 miles
• 10/27/20 Checked valve clearance @ 13,736 miles. All were within spec.
• 10/27/20 Checked throttle body sync at 13,771 miles. No adjustment needed.
• 10/29/20 Replaced swingarm pivot bearings with RULMAN ART 30203 Tapered roller bearings @ 13,771 miles
• 10/29/20 removed drive line to inspect splines and u-joints. Cleaned an lubed all splines $13,771 miles
• 10/29/20 Drained and flushed rear drive. Refilled with 180cc of Valvoline 75W-140 full synthetic gear oil at 13,771 miles.
• 11/11/20 – Replaced the plastic fuel fitting with chromed brass CPC fittings @ 14,092 miles.
• 3/4/21 Installed Touratech racks and Zega Panniers
• 7/24/21 Replaced High beam bulb with a Sylvania H7 @ 15,623 miles
• 7/25/21 Replaced outer rear drive seal with OEM BMW seal @ 15,623 miles. Stock seal was weeping very little oil.
• 7/25/21 Drained and filled rear drive with 180cc of Super-Tech 75W-90 full synthetic gear oil @ 15,623 miles.
• 8/1/22 Installed new Metzler Torrance tires @16,524 miles
- Touratech Zega panniers and racks (optional)
- OEM Heated grips and hand guards
- GSA extra wide foot pegs
- Side stand enlarger
- Delkavic muffler
- Beak protector
- Sargent seat
- GSA rear rack (optional)
- Maier rear fender
- Dual (white/yellow) color mini LED driving lights
- Crash bars
