The 2017 engine upgrades definitely make the motor more peppy. 👍
Sounds pricey 🤑 but can you elaborate on that? Does that make it more noticeably peppy? Cost?Putting some SV Cams in your Strom might help![]()
This was very useful thank you!This may be useful: Wee vs Wee: 2008 and 2021
Glad it helps. I just updated it with some observations from my first multiday road trip, which I had not yet done on a Gen 3.This was very useful thank you!
It's probably only cost effective if you do it yourself. Basically you install SV cams in the WEE. Search the site there should be several threads about it. Here's one.Sounds pricey 🤑 but can you elaborate on that? Does that make it more noticeably peppy? Cost?
Thank you! That sounds like exactly what I'm looking for.It's probably only cost effective if you do it yourself. Basically you install SV cams in the WEE. Search the site there should be several threads about it. Here's one.
Cam Swap into DL650, Sweet and Easy
:thumbup: I just recently completed the Cam Swap into my DL650 thanks to the help of some capable friends and it is working perfectly as expected, What I did was install the SV650 Intakes Cam Swap, Gen 2 SV650 Intakes on DL650 Intake Side, and Gen 1 SV650 Intakes on the Exhaust Side, Front...www.stromtrooper.com
What does this trade off? Presumably low end torque for horsepower?It's probably only cost effective if you do it yourself. Basically you install SV cams in the WEE. Search the site there should be several threads about it. Here's one.
I love the comfort and fit of the bike (I'm 5' 5" so i have a hard time getting a low enough seat height. And I don't like to lower a bike) and I like being able to carry all my stuff for trips. It would be more fun if it had more pep and better brakes. Those are the 2 improvements I would make. And move the air filter so it's easier to do basic maintenance 🙃The SV cam swap may gain you some higher end HP at the cost of low end torque, depending on how you ride this could be of benefit. But I think the main reason your SV650 felt peppier was it was a good deal lighter than your DL.
Personally if you feel the DL isn't peppy enough, you may really need a different bike.
That makes my legs tired just thinking about pedaling in the small front ring all the time! 😆Cheap Pep would be changing the front sprocket to a smaller one, like a 14 tooth. This will have the same effect as shifting from the bigger to smaller front sprocket on a 10 speed bicycle.
Drawbacks: less top speed, slight drop in mpg. A worn chain will wear a new sprocket out faster. Best time to do a sprocket swap is when also changing the chain and rear sprocket, which ain't cheap, but necessary sooner or later anyway.
My friend has a 2014 1000 he's gonna let me ride today to see the difference.2014 & up 1000 Strom will get ya what youre lookin for. & only around 30lbs heavier than the 1st gen 650
+ waaay better brakes & suspension adjustability
I understand the switch from the SV to the DL, I did the same thing (2006 SV650) for the same reason, more comfort and carrying ability.I love the comfort and fit of the bike (I'm 5' 5" so i have a hard time getting a low enough seat height. And I don't like to lower a bike) and I like being able to carry all my stuff for trips. It would be more fun if it had more pep and better brakes. Those are the 2 improvements I would make. And move the air filter so it's easier to do basic maintenance 🙃
