Well maintained 2006 V-Strom 1000cc. I have all the maintenance records and they are up to date. The valve clearance and shimming, new tires, new coolant, new brake pads, and K&N filter were all done about 3,000 miles ago so you have a while before you need to mess with anything. It has not had the clutch basket mod and does make some chudder sound. From all I've read this does not cause a clutch to fail though. It will need a new chain in about 1,500 miles.
Extras/Accesories:
-I have Givi 36 Liter side cases that I can throw into the deal for $200 more.
Extras/Accesories:
- Lowered Foot Pegs (For comfort)
- Aftermarket raised handlebars (higher bars)
- Barkbuster Handgaurds
- Madstad Windscreen Bracket (OEM Windscreen)
- Hepco and Becker crash bars
- Skid Plate (Enduro Guardian I believe) with highway pegs attached. Very comfortable.
- Givi side case and top box mounts
- Givi top case with dedicated key lock
- Spacer kit to exactly align chain (known design issue on v strom)
- USB plug and 12 v cigarette lighter outlet added in and mounted with clean dash plate. It only powers when keyed on so you don't run battery down.
- Ohlins aftermarket rear shock (very expensive)
- Custom fork build on the front for improved suspension. Includes fork boots to protect fork cylinders from damage causing seal leak
- Includes Wolfman Enduro tank bag
- Enlarged Kickstand foot
- Probably more extras that I can’t recall right now
