1 - 10 of 10 Posts
Hi.
I just change my front and rear sprocket to 16 43, and put a new chain on it.
I went roadtesting and I have a problem. My speedo does not work anymore. The needle doesnt move. Do you know what could be the problem? Is the smaller gear does get ''read'' by speed sensor?
Thanks alot, and sorry for my english, im from Quebec Canada!
Is the sensor plugged in? Did you disconnect it when you worked on it? Or maybe you forgot to put that little square-ish thing (not sure what it's called but it's kind of a square with 4 notches and a central bolt hole and held in by a hex drive bolt) that the sensor picks up?
Yeah anyone looking for a life changing experience, ride your bike through the streets and highways of Montreal.
1 - 10 of 10 Posts
