Air filter @ 11,000
Spark plugs @ 7,500 & 14,500
Engine oil (filter every 10,000)
Valve clearance check, adjust as needed
Idle speed check (1300 rpm)
Throttle valve synch
(I like to set the throttle position sensor @ 1400 ~ 1700 rpm)
Engine coolant (2 yrs unless you get long-life 5 yr stuff)
Brake fluid (2 years)
Inspect, clean, lube, tighten everything as appropriate and needed.
